Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
  • slimsoul
    • Mar 2024
    • 14
    • Wales
    Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
    I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
    I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
    The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power up displaying the same symptoms as the UE32J5500AK, i appreciate that the 2 issues may not be the same but i would like to diagnose the correct parts to replace.
    I have replaced a power board previousy on another TV and have minimal skills electronically but can use a meter to test etc
    Simon
  • nomoresonys
    • 12229
    • U.S.
    First test, unhook cable from powerboard to mainboard, plug power cord in, see if backlights come on and stay on, need at least a focused picture of each board and one of the whole back including all the boards.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      I have just repaired the ue48 model and yes was a backlight issue do the test as described in post 2
      • slimsoul
        • Mar 2024
        • 14
        • Wales
        Thanks for the reply, will do this.
        • slimsoul
          • Mar 2024
          • 14
          • Wales
          UE48H6400AK
          Removed cable from power board that was hooked up to the main board, plugged power cable in and the back lights came on and stayed on?
ID:	3234390 Click image for larger version
ID:	3234391 Click image for larger version
ID:	3234392Click image for larger version
          UE32J5500AK
          Same method as above bu no back lights came on (on this set the red standby light blinks every now and again, doesn't stay on)
ID:	3234395 Click image for larger version
ID:	3234396 Click image for larger version
          • lotas
            • Jan 2016
            • 4710
            • Russia
            Originally posted by slimsoul
            UE32J5500AK
            [ATTACH=JSON
            {"data-align":"none","data-size":"thumb","data-attachmentid":3234395}[/ATTACH] Click image for larger version
            How did you manage to disconnect the cable between the power supply and the motherboard on the UE32J5500AK, if this board is two in one (motherboard + power supply)?
            • slimsoul
              • Mar 2024
              • 14
              • Wales
              Disconnected the white 8 pin connector assuming it was going to a main board. Can the power be removed on a 2 in 1?
              • lotas
                • Jan 2016
                • 4710
                • Russia
                Well, how do you turn it off, of course not.
                • slimsoul
                  • Mar 2024
                  • 14
                  • Wales
                  vinceroger69 nomoresonys do you guys have any advice on the next step to diagnose the fault on the UE48H6400AK?
                  Seems like the UE32J5500AK is a different setup and has a 2 in 1 main/power board and i was unable to remove power to complete the test, is there any other test i can complete for this setup?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    Hi on the 48 inch set it maybe a firmware issue hopefully lotas or diah can advise
                    • lotas
                      • Jan 2016
                      • 4710
                      • Russia
                      Да, серия xxH6xxx играется со слётом прошивки, иногда помогает только перепрошить 25Q40, бывает что и в eeprom 24C512 и в eMMC.
                      • slimsoul
                        • Mar 2024
                        • 14
                        • Wales
                        Can this be resolved by replacing the mainboard? From a translation of your reply, flashing is possibly out of my skill set of special tools are required.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          yes a mainboard swap should work fine just make sure you match all the numbers up from on your old mainboard and make sure you buy a board with a returns policy just incase it arrives faulty
                          • slimsoul
                            • Mar 2024
                            • 14
                            • Wales
                            Thanks for the help vinceroger69
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              This maybe the rite board just double check before you buy https://www.ebay.co.uk/itm/203929521...Bk9SR-CIk-THYw
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                Your 32 inch set may also be a firmware issue as they sell a pre programd ic to solve the issue your having maybe contact the ebay seller as not 100% this is for your exact tv https://www.ebay.co.uk/itm/334790152...Bk9SR6Tcw-THYw
                                • slimsoul
                                  • Mar 2024
                                  • 14
                                  • Wales
                                  vinceroger69 UE32J5500AK​ - Spoke to the seller and he has requested i diagnose the fault first as the cpu failure is also common, is this something i can check?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    I have not worked on these all in one boards before i have just re read your first post and you mentioned you have changed this board already. hopefully a more experienced member who has worked on these boards can advise you better
                                    • lotas
                                      • Jan 2016
                                      • 4710
                                      • Russia
                                      For model UE32J5500AK, if you have a programmer, you can try to reprogram flash 25Q40.
                                      • slimsoul
                                        • Mar 2024
                                        • 14
                                        • Wales
                                        lotas i dont have these tools unfortunately, would a full main/power board swap fix this (its possible the main board i swapped initially could have been faulty also)
                                        • kca
                                          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                          by kca
                                          Hello all ~
                                          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                          No picture. No sound.
                                          I tested all the voltages coming out of the power supply...
                                          10-12-2023, 05:23 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
